Gasket for PTO shaft on TO30
Ark Pisarevsky
09-05-2001 06:00:10
I am about to remove PTO shaft from TO30 so that I can pull remains of mangled adapter off of it. The repair manual is still on order so I have a few questions before starting.
Is there a gasket behind it that I should be replacing ?
I searched through advertisers on this site and can't find any info.
Also, I am thinking about installing a 1 3/8 inch shaft to replace 1 1/8 that is there now so that I don't have to use an adapter. Any suggestions on where I may be able to find one ?
Thank you in advance for all the help. I learned a ton from this site.
Ark.
Larry in Missouri
09-05-2001 19:06:52
 Re: Gasket for PTO shaft on TO30 in reply to Ark Pisarevsky, 09-05-2001 06:00:10
I bought a 1 3/8 shaft from my MF dealer in Washington, Missouri, for about $120. This included the bearing and attachment plate and gasket, too. They didn't have the original size in stock, so I got this one. Then I had to get an overrunning clutch for it. Since you can get these clutches with either 1 1/8 or 1 3/8 input splines and 1 3/8 output shaft, it really doesn't matter much which shaft you get. I got mine at a local farm store, but the MF dealer says they break all the time. Well, I've got a lot of hours on this one, and so far so good!
Terry G
09-05-2001 13:52:11
I replaced the old 1 1/8" pto shaft on my TO-20 with the 1 3/8" and have never been sorry. The shaft I bought came with the bearing, seal, and housing all assembled. All I had to do was unbolt the old one and slide the new one in, with a new gasket of course. Park the front wheels in a ditch so the oil don't run out when you pull the shaft. Then, like everyone says, get an ORC if you are going to bushhog. Ain't old tractors fun?
Terry G
Phil (VA)
09-05-2001 12:14:14
I'm confused about "adaptor" which I assume is to step up to 1 3/8, right? It should be totally on outside of housing, so hard to imagine why you need to remove the shaft. Anyway, assuming you do, there is a seal, yes. Also Stevens, Coushatta (sp?), LA sells both size PTO shafts, for about $100 or so. If you are going to do any bush hogging, you will need an override clutch (ORC), and these come in various shaft sizes, e.g., 1 1/8 female to 1 3/8 male which in effect adapts the size as well as providing ORC capability, and there is no appreciable price difference regarding the ORC size options. Just my thoughts, but, as I said, I am a little confused on your situation.
Ark Pisarevsky
09-05-2001 12:33:25
 Re: Re: Gasket for PTO shaft on TO30 in reply to Phil (VA), 09-05-2001 12:14:14
The front part of the adaptor was munched and twisted off when I hit a rock with a bush hog. What's left of the adaptor is wedged on PTO shaft and is inside the flange that is part of the housing for the shaft.
I tried cutting it with a Dremel so I could split it but couldn't reach far enough inside the flange to do it.
Thank you for the pointer to the source of parts. I'll contact them.
Ark
