Fegurson plow
Larry McComsey
04-06-2008 16:23:21
I purchased a Ferguson plow type 12-ao-40 serial #1409. Could any one tell me around when this plow was made, also it has cast iron shears does any one know it they make a steel replacement shear or if replacement parts are available for these plows Thanks Larry M.
AussieDoc
04-07-2008 17:20:20
 Re: Fegurson plow in reply to ArleninOr, 04-06-2008 16:23:21
I can't help. But I was at a tractor rally last Sunday. Perfect weather.
I watched 4 Fergies together plow a display paddock. In the background there were old stationary and steam engines chuffing away, putting out the sounds and smells of yesterday as I munched on a hamburger cooked by volunteers. Ah...the simple things in life.
Scott Pa
04-06-2008 16:58:22
 Re: Fegurson plow in reply to Larry McComsey, 04-06-2008 16:23:21
It was made around 1945. To tell if steel shares are available please give us the number from the back of an old share or moldboard since many different styles were available.
Earl -IL
04-09-2008 08:19:27
 Re: Fegurson plow in reply to Scott Pa, 04-06-2008 16:58:22
Scott, Please contact me by email or phone. 217-586-3604 .Thanks Earl
Larry McComsey
04-07-2008 17:20:56
the numbers on the back of plow shear or share I not sure witch is correct are 12 1C AO181 below that is DDS S Thanks for any Infomation you can give me Larry M
guyeli
04-07-2008 05:01:39
Hi Scott,
I have an old 14" 2 bottom Ferguson plow.The numbers on the moldboard are:14R-AO-112 or somthing close as the characters are hard to read.Do you have a replacement mold board and how much would it cost? shipping? ect.
Thanks,
Guyeli.
Jeff-oh
04-07-2008 05:49:01
 Re: Fegurson plow in reply to guyeli, 04-07-2008 05:01:39
I have found many plow parts here. I think youll find the what you need. The mouldboards are listed undr PN MF 660010 & 660002
Jeff
