Down Pressure on Loader for TO-20
Dan Oehmke
04-04-2008 11:46:31
I finally the front pump and loader installed on my TO-20. It works pretty nice, except the gravity drop on the loader arms really goes fast and rocks the tractor when releasing the valve handle. Would two-way hydraulics with both up and down pressure smooth this out? Like the bucket which has pressure both ways and operates very smoothly.
Thanks,
Dan
Gerald J.
04-04-2008 17:45:37
 Re: Down Pressure on Loader for TO-20 in reply to Dan Oehmke, 04-04-2008 11:46:31
Plumb in a one way flow restrictor valve on the loader lift cylinder hydraulic line. Such as on with a micrometer adjustment of rate made by Cross. Then you set the lowering rate with the micrometer adjustment. I bought a couple one time from Northern Tool (as they are known last I checked).
Otherwise sand your finger tips and barely open the valve when lowering.
Gerald J.
Dan Oehmke
04-05-2008 06:16:45
 Re: Down Pressure on Loader for TO-20 in reply to Gerald J., 04-04-2008 17:45:37
Gerald, think I'll look into this because not sure I can sand down my fingers enough to be that "precise." It is possible to barely move the lever...but you need to be paying attention!
rich4
04-04-2008 17:03:44
Can you just move the valve slowly, it should be progressive to a point. A one way valve may be faster than a two way. But you should be able to just move the lever a fraction of an inch to lower slower.
Dan Oehmke
04-05-2008 06:14:06
 Re: Down Pressure on Loader for TO-20 in reply to rich4, 04-04-2008 17:03:44
I worked w/it a bit more last night and yes, if I'm very gentle with the valve control lever it works pretty good --- but you need barely need to move the lever and it's easy to overdo it!!
Bruce(OR)
04-04-2008 13:24:36
Dual valve and dual cylinders and more money...
I have a loader that will do the same thing, ever I get it hoooked up again. My plans are to build a stop or install a spring on the control that will only allow "X" amount of control arm travel.
Bouncing the tractor was fun! (?) I was thinking of putting batteries on the back for counterweight and going to Mexico...
Richard L
04-04-2008 13:52:55
 Re: Down Pressure on Loader for TO-20 in reply to Bruce(OR), 04-04-2008 13:24:36
Bruce, I'll bet that would be a very nice scenic trip I wish you a lot of fun. LOL Keep this forum posted so we know how you are doing. Richard
