Bob(Aust) pertronix?
rusty nut
02-19-2008 15:57:06
do you know the part# for the pertronix 12volt negative ground lucas dizzy? I have 48 TE20
Bob (Aust)
02-20-2008 19:43:50
 Re: Bob(Aust) pertronix? in reply to rusty nut, 02-19-2008 15:57:06
Well, there is an interesting point to keep in mind!
It appears the TE20, made in the UK with Continental engine, has the same Lucas D3A4 distributor as the later TEA20, made in the UK with the Standard engine!! I thought the Z120 engine had a gear driven distributor, as the Lucas distributor has an off-set quill drive.
Rusty, you mention your tractor is negative earth. Once you've installed the Pertronix Igniter, don't reverse polarity or you will instantly fry the unit!
Here's the Pertronix Igniter installed in the Lucas distributor in my TEA20:
third party image
No condenser, no points - no more problems!
You will not be disappointed!!
Bob in Oz
DennisPinOhio
02-20-2008 03:10:19
I put one on my 1948 TE 20 (sn 28383).
With help from John(UK), I contacted vintage performance(dot)com/retrorockets/lucas.htm, who provided the exact unit I needed.
Part number is LU145 and it cost about $93 USD.
Best investment I could have made.
My distributor is a Lucas, model #D3A4.
Good luck.
Bob (Aust)
02-20-2008 00:42:31
The Pertronix LU-145 Igniter suits my 1953 TEA2085 (Lucas D3A4 distributor) negative earth.
I checked the 2007 Catalogue and can't see the Ferguson tractors listed.
You will have to contact Pertronix by email, give them your tractor model; year; distributor make and model, and I know they will have an Igniter to suit.
Bob in Oz
Bob (Aust)
02-19-2008 20:34:48
Rusty.
Is it a TE20 Continental engine, or TEA20 Standard engine?
According to the latest 2008 Pertronix Catalogue - I can't find Ferguson tractors or the TE20!!!
It is definitely in the 2007 Catalogue. I'll look when I get home tonight.
Bob in Oz
rusty nut
02-20-2008 14:06:50
 Re: Bob(Aust) pertronix? in reply to Bob (Aust), 02-19-2008 20:34:48
it is a te20 continental thanks for the info I appreciate it.
