Carb welsh plugs
Jeff-oh
02-11-2008 06:27:56
I saw the discussion in a post below. When I took a small engine repair class I rebuilt the carb on an old Briggs "tiller" motor. I poped the welsh plugs and put the new ones in. However, I could not for the life of me figure out what or why they were there. The just plugged up a hole.
Only thing I could come up with is that when making the carb, the holes were needed for tool access during manufacturer, and then they were blanked off. Or that they were there to provide a cleaning access port.
As I remember it was a bear to pull the old plug and a bear to put the new one in. And I could not see how it could make a difference.
Anyone Know the what and why's of welsh plugs?
Jeff
rusty nut
02-12-2008 18:08:17
 Re: Carb welsh plugs in reply to Jeff-oh, 02-11-2008 06:27:56
gerald is right,I had an old timer tell me that,I forgot about that until I just read it again
Gerald J.
02-11-2008 10:14:03
Drilled passages can't all be straight. Some need to bend. Drills don't bend reliably, so the holes come to air and get plugged.
The reason you removed the plugs was to allow complete cleaning of the drilled passages which are often small diameter and easily plugged. If all you did was change plugs, you wasted all that work.
Gerald J.
Jeff-oh
02-13-2008 04:57:50
 Wait!!! what are you telling me!!!!! in reply to Gerald J., 02-11-2008 10:14:03
You mean that they cannot drill around corners... Wow no wonder the shop guys hate my designs and blueprints!!! :)
No really, I am always amazed at what the machinists can do with the crazy designs we come up with. It is truly sad that we are not investing in apprentice programs for the skilled trades. Thanks for the input, that's what I thought they were for. I guess the question came up because the Briggs service manual just had a section on remove and replacement of the plugs. I did use the opportunity to clean the passage.
Jeff
Jerry/MT
02-11-2008 08:36:41
Jeff, I think you"re right about the holes on the carb. They may have beeen tooling holes and the plugs just used to keep the mud daubers and other stuff from making a mess in them. Usually Welsh plugs are used fill the core plug holes on castings (like engine blocks) and at the back of the block where the rear cam shaft bearing is at. They are comomly called "freeze plugs" but that"s not their purpose.
