Fan Blade/Water pump pully ?
Covert
10-07-2007 11:29:48
Put a new belt on today, ran her for a few min's and the pully attaced to the fan seperated from the part that drives the fan. Now this pully is over the water pump. Do the the fan and pump share the pully. ANd if so where do I buy a new one?
Covert
10-12-2007 10:30:56
 Re: Fan Blade/Water pump pully ? in reply to Covert, 10-07-2007 11:29:48
yeah pully part seperated from the hub, got a new one today and its about 4 times as thick, this one was machined not pressed together so this will never happen again.
John (UK)
10-08-2007 12:31:11
The pulley is part of the hub and should not come apart, go to this site and select your part.
http://www.ytmag.com/cgi-bin/store/model_parts.cgi?SearchArea=FE&&md=TO20&cat=Cooling%20System&r=mcats
Jerry/MT
10-07-2007 18:59:20
The fan, the pulley, and the water pump are connected by bolts per the Parts Manual. Are you saying the pulley broke off? Are you sure that the bolts didn"t just come out?
Covert
10-07-2007 11:30:48
1950 TO-20
