FERGUSON PLOW
milton r. sahms
09-11-2007 17:11:15
I JUST PURCHASED A TWO BOTTOM FERGUSON PLOW AND WAS NOT SURE WHAT SIZE IT IS.IT HAS NUMBERS ON PLATE 2-16C-AO-28,I WAS TOLD IT WAS 14' BUT NUMBERS WOULD INDICATE 16'.NOT SURE IF THEY MADE A TWO BOTTOM 16' PLOW.I HAVE SAND BLASTED AND PAINTED THE PLOW AND ALL THE PARTS APPEAR TO BE THERE.
FergieFlyer
09-11-2007 20:00:13
 Re: FERGUSON PLOW in reply to milton r. sahms, 09-11-2007 17:11:15
third party image
Does it look like this? Here is a picture of my 2-16C-AO-28 plow, serial #1260. It's a 16" plow. They aren't as common as the 2-14's. I think most of the 2-16's have that angled bar running from the top link to the back of the frame. If you stick that 2-16 in the ground behind your Fergie it will really make it work! Does a nice job of plowing, though. My grandfather would open the field up with the 2-14, then do the rest with the 2-16. Mike
phil(va)
09-11-2007 17:57:17
Should be a double sixteen based on number. Measure in inches between the beams. Measure from same spot on one beam to that spot on the other, i.e., middle to middle, etc. Is it 16 inches?
