'53 TO-30 starting problems
JonnyMike
07-12-2007 00:52:00
I've owned my to-30 for 6 years now and for the most part it has run just fine, even though I didn't really do anything to it after buying. Been having a few starting & bogging down problems the last couple summers but with the info contained in these great forums, I've managed to keep my machine running. I have noticed that on occasion after heavy rains, I've had to replace the condenser to get it to start. This latest time, however, it still won't start so tommorrow I'll begin systematically going over all the electric components. If unsuccessful, I'll definitely post a new SOS. In the mean time, I'm curious about what exactly the condenser does and how it's integral with the ignition system? If anybody out there could educate me on this I'd appreciate it.
marshalljd
09-08-2007 22:50:00
 Re: '53 TO-30 starting problems in reply to JonnyMike, 07-12-2007 00:52:00
would like to know what answer you get,Ihve a similar problem with my TO 20. it won"t start
Jerry/MT
07-12-2007 12:22:53
Bob has explained the operation of the condensor very well and I agree with him regarding the Pertronix system as I have one on my '54 TO-30.
While I do not agree that it provides any increase in power,(power increases only if you have a misfiring ignition system as a basis for comparison) quick starts in all kinds of weather, smoother idle, and the maintenance free aspect appeals to me.
The quick way to check the spark is to pull the center wire out of the distributor cap, turn on the ignition switc, hold the wire near a good ground and try s atrat. You should have a FAT, BLUISH-WHITE SPARK. If you don't, start checking the primary ignition circuit from the battery through the key switch to the coil to the points and to ground. Make sure that the wire between the coil and the distibutor is attached to the coil connection that is th same as the battery ground. Don't forget to check the charging system to make sure that you voltage regulatoris not causing a greater voltage than about 13.6 V or you could be burning points.
Systematically mmake measuremenats and record the numbers. record any changes you make, one at a time, and record the results. Get back here if you need to consult with the folks on this forum. Good luck!
JonnyMike
07-13-2007 12:56:40
 Re: '53 TO-30 starting problems in reply to Jerry/MT, 07-12-2007 12:22:53
Thanks Bob & Jerry for your quick responses. Replaced a bunch of old wiring yesterday, tested ignition switch, etc. Attempted to start after each process. Achieved immediate success after changing out the points. Unfortunately, it"s the wettest summer ever here in Oklahoma (rained almost every day since June 1) and my property is too soggy to mow. At least now I know the tractor will start when it does dry out.
Regarding the recommended 13.6 V charging level, my dashboard ammeter shows just below the 15 V mark when idling (the gauge has 5 V increments). When the engine"s revved up, the meter jumps up substantially. Haven"t checked it under a load yet.
Pulled, inspected, cleaned the spark plugs, which were Motorcraft BTS10 (haven"t had a chance to get new ones yet). All except #4 looked good (relatively speaking). #4 was quite oily with alot of hardened black deposits. I doubt if it was even firing. Anyway, after cleaning it up and re-installing, the engine ran smoother.
Re: the Petronix system, is this something my local tractor supply or auto parts stores will carry? Or do you have to buy it online? Also, will I need to convert from 6 V to 12 V for the Petronix to work?
Thanks in advance gentlemen for your advice.
Bob (Aust)
07-12-2007 03:03:34
"Current exits the coil's primary winding and begins to charge up the capacitor ("condenser") that lies across the now-open breaker points. This capacitor and the coil’s primary windings form an oscillating LC circuit. This LC circuit produces a damped, oscillating current which bounces energy between the capacitor’s electric field and the ignition coil’s magnetic field. The oscillating current in the coil’s primary, which produces an oscillating magnetic field in the coil, extends the high voltage pulse at the output of the secondary windings. This high voltage thus continues beyond the time of the initial field collapse pulse. The oscillation continues until the circuit’s energy is consumed."
A capacitor or condenser is a dialectric device that stores electrical energy. Computers use a heap of capacitors to level out electrical energy. If you get the chance, get hold of one of those large can type capacitors, around 10,000 micro farads, 60 volts working, charge it up and put a wet finger across the points. Guaranteed to curl your hair!
I gave up and installed a Pertronix Electronic Igniter system. No condenser, no points - no problems!!! Easier starting, smoother running, quicker revving and more power.
Disclaimer: I am not associated with Pertronix in any way. Just happen to think their Electronic Igniter system is the greatest thing (for antique Fergys) since sliced bread was discovered and fail to understand why you all persist with primitive, Jurasiac condenser and points ignition systems!
