1969 Massey Ferguson (gas) PTO Low power NEED HELP
Mary J
06-16-2007 14:27:59
Hay Cut & Raked...Hydraulic fluid filled...hoses checked...NO POWER :(
Need Help Please
John(UK)
06-17-2007 07:13:53
 Re: 1969 Massey Ferguson (gas) PTO Low power NEED HELP in reply to Mary J, 06-16-2007 14:27:59
If you have a 1969 tractor I am assuming it is either an MF35 or 65. If it has live-drive transmission (Dual-Clutch) then maybe the PTO Clutch is slipping, that would account for loss of power. On the single Clutch it would slip driving the wheels too. If it is a Live-drive, there may be some adjustment that can be made but usually when they do this the engine needs to come out and the Clutch assy. overhauled or replaced. If want to discuss this further, email me at:- fergusontractors(at)tiscali.co.uk
tell me what the tractor is and as much as you can.....John
Gerald J.
06-17-2007 13:23:48
 Re: 1969 Massey Ferguson (gas) PTO Low power NEED HELP in reply to John(UK), 06-17-2007 07:13:53
Since 135 and 165 production began about 1963, a 1969 tractor would be one of those, not a 35 or 65.
Could easily be that the PTO isn't shifted into engine driven gear.
Gerald J.
John(UK)
06-17-2007 13:54:26
 Re: 1969 Massey Ferguson (gas) PTO Low power NEED HELP in reply to Gerald J., 06-17-2007 13:23:48
If it wasn't in gear it wouldn't be classed as LOW power...more like NO power I would have thought. there is no difference in the operation of the 35 / 65 and 135 / 165 pto drive.
Jerry/MT
06-16-2007 22:13:45
No one on this forum is a mind reader. It would help if we knew the model of tractor and the specifics of the problem. "Hydraulics filled...hoses checked.. NO Power..." just doesn't cut it. Is there no power to the PTO or no hydraulics to the baler, or both.....????? ?????
Lance J.
06-16-2007 17:25:04
Could you be more specific on the problem you"re having? Is it with the PTO, three point lift, or other hydraulics? Let us know.
