Dearborn loader for TO-30
idvarmint
05-03-2007 16:32:26
I have a 1950 TO-30 and found a Dearborn 19-8 loader that came off a Ford 8N. Will the Dearborn 19-8 fit on the TO-30 frame? What do I need to hook up the pump? If the Dearborn fits, what's it worth? If it won't fit, what loader will work best.
phil(va)
05-06-2007 06:02:10
 Re: Dearborn loader for TO-30 in reply to idvarmint, 05-03-2007 16:32:26
If it worked on the 8N, it will fit the TO-30. I have a Wagner loader that came off an 8N on my TO-30 and it bolted right up. Axles must be same length apart or mine would not have worked. As to hooking it up you need a stinger for the front pump and your tractor needs the special pully adapter to accept the stinger. I believe these are available from New Holland dealers.
rusty nut
05-04-2007 17:59:36
I have a 51 TO30 and have a lord loader,love it,does everything I need it to do.
idvarmint
05-05-2007 21:58:12
 Re: Dearborn loader for TO-30 in reply to rusty nut, 05-04-2007 17:59:36
What"s the model?
Bruce(OR)
05-04-2007 00:29:29
Take a look at page two on this site regarding TO-20 front pump connect...
