Generator off the PTO
Frank Biscardi
01-19-2001 19:28:55
I have been playing with the idea of getting one of those generators that attach to the PTO for back up power. When the lights go off here we are the last to get them again as we live out in the country.
Does anyone know how many RPMs these generators require? Is it hard on the tractor to have it idle that long? How long will a well tuned TO-20 run at fast idle with 10 gals of gas?
Thanks
Frank
Jack in NB
01-20-2001 05:07:30
 Re: generator off the PTO in reply to Frank Biscardi, 01-19-2001 19:28:55
Good morning, Frank -
Most PTO generators are geared to run at 540 PTO rpm - about 1500 engine RPM - 2/3 throttle.
You should get 12 to 15 hours running on 10 gal of fuel with varying load on the generator. At idle, you could expect 20 to 30 hours running.
Shouldn't be hard on the engine if the thermostat is working and the engine temp is up, but if it's running cold, you will shorten its' life a bit. Idling is worse than 1500 rpm in this situation.
There is more of a risk of running low on oil - keep an eye on that. Fancy units have an engine protection package (Murphy gauges are a common one) - monitors engine temp and oil pressure, and shuts down if they get out of line.
The power from this set-up is more expensive than from most utilities, but sure is nice to have!
Hope this helps.
