Fender question
TOMan
04-03-2007 05:17:19
Are Ford 8n &9n fenders the same as a TO-20?
Glenn/Calif
04-04-2007 15:24:41
 Re: Fender question in reply to TOMan, 04-03-2007 05:17:19
TOMan: Might take a look at the photo ads at left under Parts. Set of Ferguson fenders for $100. Don;t know if they are of interest but thought I would mention. LOL Glenn
Randyr
04-03-2007 19:19:56
I bought a pair for my 35 from an all purpose scrapyard/recycler/new parts dealer. They were made by a company called "Hy Capacity". I asked the guy what the difference was between these an Ford N fenders, and he said it was the paint color. So it sounds to me like they will interchange.
I had a devil of a time getting the long bolts out. Once out I cleaned out the holes with a rotary brush in a drill, and applied anti-seize compound to the bolt shanks, and in the holes. Maybe I'll have to pull them out every few years and clean things up so they don't stick.
Indiana Jones
04-03-2007 16:03:33
I've started painting my TO30 and have a real nice pair of 8N fenders that I went to put on it this past weekend. WRONG! After yanking the rear wheel and removing the nuts on one side, I couldn't get the bolts to budge. Guess I could have kept working on them and eventually got them out, but after a while the fenders that were already on it got to looking better and better. I am leaving them on. On the other hand, the original fender bolts on my 9N Ford came out relatively easily when I pulled them off last year. Maybe yours will be cooperative.
Bruc
04-04-2007 09:57:23
 Re: Fender question in reply to Indiana Jones, 04-03-2007 16:03:33
Long bolts...I cut mine in half with a cut off tool and then either the top or bottom part came out easy. A long punch and hammer made the other half finally come out. PB Blaster penetrating oil also did it"s fair share to assist.
john [mo]
04-03-2007 20:08:13
i ground the rivets off the brackets and removed mine from the tractor. then put bolts back in place of the rivets. the rivets were not easy to punch out but i did not want to fight those bolts.
John (UK)
04-03-2007 09:03:44
Very similar if not the same in some cases. They will interchange, which is what you want to know I would think. Best of luck getting the long bolts out though.
