Electrolysis update
John (TR)
03-19-2007 20:11:45
Last fall I experimented with electrolysis with fair to poor results. I could never get more than about 3-4 amps and results were painfully slow. Tonight I drug out the equipment and started over this time adding a battery in paralell between the charger and the tank and I'm off and running with 8 amps and boiling like crazy!
Bill Brox
03-20-2007 00:54:13
 Re: Electrolysis update in reply to John (TR), 03-19-2007 20:11:45
Hi there,
What electrolysis is it you are doing ? Removing rust ?
Bill
John (TR)
03-20-2007 04:26:38
 Re: Electrolysis update in reply to Bill Brox, 03-20-2007 00:54:13
General rust removal. I'm cleaning a fan shroud for my 8n now. Once I get the system to work I have a number of parts like an original Tarus rear light, original Ford work light, original Ford 9n tool box etc which all are great candidates for electrolysis. I have 2 Fords in addition to my TO 35 and I'm always on the hunt to upgrade parts especially for my 43 2n.
I have a sand blaster and sand blast cabinet also but I like the fact I can set up the part, turn it on and go do something else.
Bill Brox
03-20-2007 07:08:01
 Re: Electrolysis update in reply to John (TR), 03-20-2007 04:26:38
Ok. I did a lot of rust removal that way last year. A 50 gallon barrel, but I have very little current. No boiling, and the result gets very good. In fact I am amazed of how well it works, but it takes time. The time I allow it to take gives the process a chance to redo some of the rust back to iron before the rest of the rust gets loose. And then I use the pressure washer to remove all the rust, dirt, paint and whatever.
I think the ideal current is about 13 milliamps per square inch. I use only a battery charger to get it done. But I admit, it is a large charger, 40 amp I think.
Good luck.
mike a. tenn.
03-20-2007 05:04:44
hey john...last i heard you were splittin' that ford to rework the oil pump. how'd that go, you got 'er back together yet?
-mike
John (TR)
03-20-2007 15:50:53
 Re: Electrolysis update in reply to mike a. tenn., 03-20-2007 05:04:44
The block is at the machine shop now. Its getting lightly decked and they are pinning the main caps and oil pump (part of the front cap) and then line boring. They tell me the old blocks aren't acurate (too much slop in the bolt holes) I'm understanding on the theory but think its a little overkill as how many of these are running without pinning the caps? Im also haveing the valve seats cut/ground/replaced as necessary.
I guess I'm relying on thier 30 years of race motor experience, I'll probably not be disapointed in the results but grumpy with the bill.
mike a. tenn.
03-20-2007 16:47:00
 john (tr) don't paint that 35 in reply to John (TR), 03-20-2007 15:50:53
sounds like you better keep it a work tractor. after paying for all that you aren't gonna be able to afford another one. i'll be interested to see how wel it runs after all that fine tuning.
