Clutch release lever adjustment
Greg in MS
02-25-2007 06:11:50
I am trying to adjust the clutch release levers on a TO-35 (single stage clutch). One of the manuals shows a "shop tool" that I don"t have, but doesn"t give any dimensions. Right now I have the contact end of the levers adjusted to 1.38" above the hub (large hub) of the clutch disc. Is this reasonably correct? Does anyone have these dimensions? The I&T manual says to adjust to a height of 1.79 from the surface plate? What is the surface plate? None of the the levers will adjust nearly that far away from any part of the clutch disc.
