3 wire Alt question
slideways
12-16-2006 09:41:19
Just wanted to confirm.. on the 3 wire alternator that i've been told is a stock Napa part for a 76-88 Chevy pickup.. Is that still internally regulated? I just need to run one wire to +.. the next to ground and the other to a diode/idiot light? And change the pulley to one that fits my belt.. right?
Thanks
Vaughan
12-16-2006 10:40:59
 Re: 3 wire Alt question in reply to slideways, 12-16-2006 09:41:19
I used a two terminal oil pressure switch to "excite" the alternator when my 1946 Farmall "A" was converted to 12V. It has a mag with a "kill" switch, not an igniton switch. This is just information passed on for anyone that may be converting a tractor with a mag.
The next one I plan to convert is my neighbor's AC "B" with a mag and will used the same setup.
Bob
12-16-2006 21:04:19
 Re: 3 wire Alt question in reply to Vaughan, 12-16-2006 10:40:59
The 2-terminal oil pressure switch in the "excite" circuit works GREAT, especially on tractors with mags.
Bob
12-16-2006 10:19:56
1988 is getting a bit too new, as it would have a "CS-series" alternator.
Asking for one for a 1975 to 1985 is a safe range.
Here's how to connect it up (again):
Third Party Image
As you know, you can substitute a #194 lamp for the diode.
slideways
12-17-2006 20:22:25
 Re: 3 wire Alt question in reply to Bob, 12-16-2006 10:19:56
Thanks again bob.. i was looking to confirm mostly that the 3 wire one didnt need an external regulator since it was essentially different then the 1 wire..
I should be good now..
Bob
12-17-2006 21:08:32
 Re: 3 wire Alt question in reply to slideways, 12-17-2006 20:22:25
Good Luck with your project!
slideways
12-18-2006 18:16:08
 Last question in reply to Bob, 12-17-2006 21:08:32
O yea.. and i hate to sound like a moron.. but when you do the 3 wire alt.. you dont have to gut the thing and replace all those parts inside right? Thats just to convert the 1 wire to 3?
When i get the 3 wire.. i just wire it as shown and swap pulleys right?
Thanks
Bob
12-18-2006 18:49:24
 Re: Last question in reply to slideways, 12-18-2006 18:16:08
If you get the factory version of the 10SI, such as for the Chevy pickup application, it will be ready to go as a 3-wire unit.
GM didn't make any of this series as a "one-wire" alternator.
That is strictly a (goofy) aftermarket setup.
