Changing engine
HammerHeadForge
10-08-2006 06:37:40
Recently purchased a TO20 in great condition. Went to a local tractor repair shop to buy an oil filter and gasket. Owner of the shop said he would not change the filter only drain and replace the oil on that model. His reasoning was "you'll never get it to stop leaking" if you remove the filter cover on the bottom of the pan. He also said you could not get parts if you bent the pan. Seems like the filter would eventually get stopped up if not replaced. Any Ideas?
DennisPinOhio
10-09-2006 06:44:13
 Re: Changing engine in reply to HammerHeadForge, 10-08-2006 06:37:40
I have a '48 TE 20 and have never had a problem with any leaking around the filter plate. I guess don't over tighten it and use a new gasket each time.
John (UK)
10-08-2006 06:43:42
Should the need arise you can buy an oil pan for your tractor. Have look at the oil pan on yours, it may not have hit anything so it will not be distorted.
