3 piont sticking TE 20
ftmfranks
10-07-2006 06:33:34
With the pto on. the 3 point works fine when working it up and down every 30 seconds. If I raise it up a little or all the way it will go all the up an stick there. It makes a clicking noise at this time. I then have to turn pto off and wait for it fall. Or bounce it around. can some tell me how to adjust or fix this? Picture of the parts to work on would be great too.
Frank
John (UK)
10-08-2006 04:03:18
 Re: 3 piont sticking TE 20 in reply to ftmfranks, 10-07-2006 06:33:34
DON'T bounce it around, as you put it, you may break something and it really isn't the way to do it. The clicking noise is the safety valve blowing off and as long as it does that it can't drop because you have maximum pressure, what should happen is when the link arms approach the top the Control Fork moves the Control Valve towards the rear and shuts off the oil to the Pump, in your case it isn't doing this, most likely the Control Valve is sticking in the lift position. I have the information you need to check this out but I need your email address to send it to, if you send it to me at:-
fergusontractors(at)tiscali.co.uk I will send the Information straight back to you.
Jerry/MT
10-07-2006 20:28:42
I think you'll neeed to adjust the control quadrant. Either get a manual or wait til John(UK) answers. He has the info in a form he can email you. You could also check the archives as this has been discussed on numerous posts.
