Alternator question
Randyr
08-18-2006 21:42:44
When converting from a 12 volt genny to an alternator, most folks say to connect the power output to the lug on the solenoid where the battery positve connects. I have connectors that will fit the bolt at the battery terminal on the battery at the other end of the wire, but not at the solenoid. Will it make any difference if I connect it at the battery instead of the solenoid, since it is just the other end of the wire? Thanks.
Bob
08-18-2006 22:06:55
 Re: Alternator question in reply to Randyr, 08-18-2006 21:42:44
What you are doing will work just fine, electrically.
Hopefully, the connection at the battery terminal won't corrode, making for a poor connection.
Randyr
08-22-2006 04:22:40
 Re: Alternator question in reply to Bob, 08-18-2006 22:06:55
OK thanks Bob.
