Engine Overhaul
Charles Oliver
07-10-2006 18:35:04
I need to do an engine overhaul on my MF-35 Perkins Diesel 3-152 motor.
From looking at the tractor it does not look like the oil pan just drops, do I really need to split the tractor just to get to my main/Rod bearings?
any advise is appreciated.
Thanks Chuck
John (UK)
07-11-2006 11:33:54
 Re: Engine Overhaul in reply to Charles Oliver, 07-10-2006 18:35:04
You will need to support the engine using an overhead crane, you can't let all the weight be on the cylinder block, it uses the oil pan as part of the strength of the engine.
