Adding water temp gauge
Overunder1
06-30-2006 11:34:27
Is there provision on the Continental Z129 block for adding a water temp gauge? I did not see reference to one in the service manual.
-Lee
TO-30
John (UK)
06-30-2006 11:57:06
 Re: Adding water temp gauge in reply to Overunder1, 06-30-2006 11:34:27
There should be a plug in the casting that supports the fuel tank at the front and the top hose attaches to it. the plug should be on the left side.
gshadel
06-30-2006 12:47:25
 Re: Adding water temp gauge in reply to John (UK), 06-30-2006 11:57:06
I installed a temp. gauge a few years back. The port John mentions is exactly right. You probably have a brass hex head plug screwed in that port now. When shopping for a gauge, avoid the typical auto parts store generic units, they will thread in, but the capillary tubing is WAY to long and you will have to carefully coil up the extra without kinking it. In addition to temp. gauges listed for the TO, I found that gauges listed for Jubilee's and Ford 600 series tractors are a perfecto fit!
George
