8n loader to-20
chris sweetland
03-21-2006 13:43:58
i have the option to buy a loader off an 8n for cheep olny question is will this fit on my to-20 with minor modifacations or should i look for an 8n to put it on i know of a couple that have been sitting for years that i think i can get cheep
phil(va)
03-22-2006 08:09:05
 Re: 8n loader to-20 in reply to chris sweetland, 03-21-2006 13:43:58
Chris, an 8N loader will bolt to a TO-30, and I presume to a TO-20, but I don't think an NAA loader will bolt right up. I think the NAA is a little longer, axle to axle, than the 8N. It might be close enough, but I'm not sure. You would have to measure the axle distance on an 8N vs. the NAA to be sure. As another post says, get ALL the hardware if you buy it. Try to get the adapter off the front pulley of the Ford if you can, as well as the front axle hardware.
chris sweetland
03-21-2006 17:05:15
sorry it came off an naa the guy wrote the ad wrong
Hobo,NC
03-21-2006 16:27:33
I have never seen a TO with a loader but would think the 8n loader would fit with out much trouble, the front mount for the loader to the front axle support will be a problem unless it comes with the loader.
Glenn/Calif
03-21-2006 16:26:59
Chris: It sure will. The one on my TO20 came off an 8N. I didn't to the installation, but I think it bolts right on. If the hardware isn't with it, it shouldn't be hard to get. Good luck.
Glenn
