Bushings
Mike Nol
02-27-2006 14:15:04
Looking for Steering Gear bushings for TO20.
Size: 1.3125" x 1.4375 x 1.2031-Part Number 180363M1
Also Clutch Pedal Shaft Bushings for TO20
Part Number 180068M1
John (UK)
02-28-2006 11:52:25
 Re: Bushings in reply to Mike Nol, 02-27-2006 14:15:04
Clutch pedal bushes are supposed to be same as the TE series 1 x 1-1/16 x 3/4 this is MF part 184592M1 or Sparex number S40740. I can't find a trace for the other bush you need, sorry.
Mike Nol
03-01-2006 07:29:04
 Re: Bushings in reply to John (UK), 02-28-2006 11:52:25
You know your parts. Thanks
john savoy
02-27-2006 18:14:46
My dad has a massey ferguson and the steering bushings were no longer available,so I bought the closest on outside dia.and machine the inside on my lathe, real tight fit.if you find a close bushing you can use brake hone and enlarge inside to fit
Mike Nol
03-01-2006 07:31:31
 Re: Bushings in reply to john savoy, 02-27-2006 18:14:46
Appreciate the idea. Thank you.
