Engine specifications for TE 20 gas.
ZANE
11-30-2005 13:48:36
What is the standard size bore and what is the standard size rod journal size? This is a TE 20.
I need a piston and rod for a TE 20 engine. It measures approx 2-900. I wrote it on my hand and then washed it off when I came in the house!!!!!
Zane
Jerry/MT
11-30-2005 18:02:46
 Re: Engine specifications for TE 20 gas. in reply to ZANE, 11-30-2005 13:48:36
Zane, the connecting rod journal diameter for the TE-20, TO-20, and the TO-30 is 1.9375-1.9365 inches. The original sleeve diameter for the TE and TO-20 is 3.1875 - 3.1895 inches and the max allowable is 3.199 inches. (Reference: Ferguson Shop Manual TO-20, TE-20 & TO-30.)
ZANE
12-01-2005 03:17:25
 Re: Engine specifications for TE 20 gas. in reply to Jerry/MT, 11-30-2005 18:02:46
Thanks guys! Now I know about where I stand with the crankshaft etc. It had a rod bearing turn in the rod and threw the rod through the block and broke the piston. The crank hit the rod one good whack but I think I can even that up with the surface of the throw and polish it a bit and then shim the new rod bearing to fit the throw if it is not out of round too much. I even have one of those old grind it in the block crank grinders that I could possibly re grind the crank round at .040 under if I had too. This is just going to be a tractor to plunk around on a small place anyway. Just hate to junk it if I don't have to. Sort of like doing plastic surgery on a 90 year old man!!!!!
Thanks again!
Zane
Duner Wi
11-30-2005 16:39:29
Zane,
Standard was 3 3/16". oversize in 3 1/4" and 3 5/16".
I don"t have book with journal sizes in the house.
Someone else may be of help otherwise I will get #"s from shop tomorrow.
