6 volt-8volt-12volt confusion
Mark from the f
11-20-2005 05:31:00
Let me state that I have read (many times) all other post regarding 6/12 volt issues.
Here's my question: I have an older 1955 to 35.
It came with an 8-volt battery. The starter ser.# tells me 6-volt starter.--However--it is set up with a neg ground system.
Quest. #1. I thought 6-volts sys. were all pos. ground (yes or no)?
Quest. #2. A new 6-volt battery and tired 8-volt battery do not give a strong enough spark to start. A 12 volt turns very fast and fires on first crank. Gen.and starter look original( I wanted that). Weak spark in points, barely visible spark at plugs (with 6v. battery). What do I do or check?
Can I have 12 volt sys. with a stupid 8-volt battery. I guess the neg. ground and weak spark from 6 and 8 volt bat. have me thinking. Also, I only get .5 at the generator-can these be rebuilt so I can keep same appearance? Thanks everybody Mark
John T
11-20-2005 06:06:30
 Re: 6 volt-8volt-12volt confusion in reply to Mark from the fort, 11-20-2005 05:31:00
Mark, I gotta get ready for church so not much time now but heres my initial thoughts.
If I was gonna convert and wanted her to crank fast for good winter starts, Im not a fan of 8 volt systems and would go ahead and convert it to 12 and be done with it.
Many old trctors, especially the 6 volt, were originally Pos ground, but Im unfamiliar with Fergusons??? HOWEVER they can work either way if the VR is compatible and you polarize the genny, so I would stay at neg ground.
If it was pos and changed to negative ground, any ammeter leads would needed swapped and the coil rewired + from switch and - to distributor.
At 12 volts you need EITHER a 6 volt coil with a series voltage dropping (12 to 6) external ballast resistor (ahead of coil n after switch) or a full 12 volt rated coil. Otherwise the coil overheats n the points burn up prematurely.
I can help you with a weak spark more later, but until then check the points and replace if badly burned or pitted and check the gap. For now I wonder about the ignition switch (may have burned or resistive contacts) or try to hot wire the coil n see how well she fires??? Your coil (from overvoltage) or condensor may also be weak. When running a 6 volt coil at 8 volts the coils run warm and the points would burn up quicker, so I wouldnt worry aobut the spark till AFTER I converted to 12,,,,, ,,got a new full 12 volt rated coil,,,,, ,,,got new points n condensor. On 6 volt systems I recommend 00 Gauge batteyr n starter n ground cables and a good ground to lessen the voltage drop when cranking which causes a weak spark.
A genny repair shop can convert most exisiting 6 volt gennys to 12 leaving the same case and you would need a new 12 volt VR of course. I have made 6 volt gennys charge at 12 volts simply by replacing the VR to a 12 volt but Im not saying thats the correct engineeirgn way to do things.
Gotta run, John T, retired electrical engineer
mark from the fort
11-20-2005 17:34:40
 Re: 6 volt-8volt-12volt confusion in reply to John T, 11-20-2005 06:06:30
I'm liking the 12 volt set-up more and more.
If I have the gen. converted to 12 V andchange the coil to a 12V-am I good to go? The starter is original and a 6 volter. Can the starter be converted as well?(will 12 V hurt it, if not?)
How about the voltage regulator? Will the other electrical components be alright if left alone?
New points and condensor-are these voltage specific? Also, I hear about 00 guage wire for ground and starter--are these pre-made or do you build your own. I was at a tractor store today and could only find 4 guage as the thickest they had. Just curious incase I give the 6 volt a shot. Thanks in advance Mark
gshadel
11-21-2005 07:56:34
 Re: 6 volt-8volt-12volt confusion in reply to mark from the fort , 11-20-2005 17:34:40
Mark, To convert to 12V, you need a 12V generator and a 12V regulator, OR an alternator; a 12V coil or a ballast resistor; 12V battery and lights of course. Your 6V starter, points/condenser are all fine. You can spend a big chunk of change to do all this.
"Modern" 12V system with alternator has to be neg. ground. I believe 12V generators are pos. ground, your stock 6V generator is definitely pos. ground.
If you already need a battery and generator rebuild anyway... it may be worth the expense. Generally speaking, converting to 12V as a means to fix poor spark or starting, is usually an expensive way to compensate for some underlying problem that is keeping the 6V system from working as it is intended. Chances are you can fix your 6V system much cheaper than converting to 12V. There ! ... I'm off my 6V soapbox now. Weak spark on 6V can be caused by bad coil, or using a 12V coil; improper point gap or burned points; bad condenser; dirty connections (big culprit) thru the ignition to coil, to distributor, or to ground; using resistor or cheapo plug wires (copper core is best); running negative ground, or having the coil wired in backwards(it does matter with 6V system).
Your generator output my be a very simple problem. Try this before spending money, polarize your generator with your 6V battery installed with pos. ground... I forget the exact polarizing procedure right now, do a quick search - I'm sure you will find it in here. Then run your engine ~1/2 throttle and connect a lead from the generator F (field) terminal to pos. ground. That will force your generator to full output. Check your generator output, volts and amps. If the output isn't > 6-7 volts, and > ~12amps or so, your genny needs work. If you get good output, then your regulator is causing problems.
George
John T
11-20-2005 18:16:11
Mark, Ive NEVER had a starter go bad when I left it original 6 volts but used a 12 volt battery but I would avoid very long cranking times so as not to overheat anything. Yes, they can be converted by a good starter n genny repair shop, but Ive NEVER had it done.
The Voltage Regulator to 12 volts IS A MUST HAVE, you will have to change any light bulbs to 12 volts.
No, the points are a pure mechanical current switching device and their voltage withstand rating is far above 6 or 12 volts anyway, so they will work as is, no difference or change required. Likewise, any ammeter isnt voltage specific, it measures the current flowing through it and isnt much concerned with the voltage across it, ideally, its a short circuit anyway. The condensor should also be fine as is.
You have to go to a regular battery supply house or maybe a heavy duty truck dealer or a welding supply house or a big tractor dealer to get 0 or 00 Gauge battery cables, the lighter No 4 like autos use drop too much voltage. NOTE if you change to 12 volts its not as critical, but I would still use 0 or 1 Gauge even then although 2 would work.
John T
mark from the fort
11-20-2005 07:54:20
Thanks for your time..... I have read many other of your replies--I'm sure other, as do I, appreciate them..... .If I have some more ?'s I may get back with ya.
Ken Crisman
11-20-2005 18:03:47
 Re: 6 volt-8volt-12volt confusion in reply to mark from the fort, 11-20-2005 07:54:20
I'm very pleased to support the issue of an 8v battery in a 6v system . I did mine almost 7 yrs. ago with no regrets . Yes it should be pos. ground . Have the voltage regulator tweaked to put 8 volts back into the battery though . I just replaced the 6+ year old battery this summer . I have much better lights & have had no problems at all with 8v . Remember if ya change to 12v you have several parts to replace . Stick to 8v , but be sure its positive ground . Ken
MikeinKy
11-20-2005 18:20:46
 Re: 6 volt-8volt-12volt confusion in reply to Ken Crisman, 11-20-2005 18:03:47
I have done what ohnT advises several times and that is the way to go. Convert your original gen. to 12V get a 12V coil with a built in resistor and a new regulator and you have 12V benifits with original appearance.
Fred OH
11-22-2005 08:00:29
 Re: 6 volt-8volt-12volt confusion in reply to MikeinKy, 11-20-2005 18:20:46
Mike...you just said the magic word as far as I"m concerned..."a 12 volt coil with a built in resistor" I have a 12 volt MF-35 that WAS a points eater till I put about a 2.5 ohm resistor in series on the 12 volt line feeding the coil. It didn"t have the resistor built in. It hasn"t had those PURPLE points since. Fred OH
