54 TEA alternator or generator
Gary Schuell
10-19-2005 11:33:07
My recently acquired 1954 2085 has an alternator on it. The mounting brackets aren't original. Did this year Fergie originally have a generator. Also, I have seen pictures of early 50's Fergies with generators - they look like starters ie, long and cylindrical vs distinctive alternator appearance. Are there alternators that look like generators?
John (UK)
10-20-2005 11:31:16
 Re: 54 TEA alternator or generator in reply to Gary Schuell, 10-19-2005 11:33:07
12 volt generators are still available and all the other electrical stuff. If you get stuck mail me.
Jim W
10-19-2005 11:54:29
It originally had a generator, and you're right, they do look sort of like a starter motor.
I am not aware of alternators that look like generators or starters.
Jim
Gary Schuell
10-20-2005 06:37:08
 Re: 54 TEA alternator or generator in reply to Jim W, 10-19-2005 11:54:29
Thanks, Jim. I'm surprised that my '54 had a generator. I read somewhere that all TEA's after serial # 200001 had alternators, or am I mixing this up with 6V to 12V conversions? Nevertheless, if it had a generator, any idea if these are available, and where?
Jim W
10-20-2005 11:00:59
 Re: 54 TEA alternator or generator in reply to Gary Schuell, 10-20-2005 06:37:08
Yes, you are mixing this up with 6 to 12 v conversions. If yours is a '54 then it will have a serial # > 200,000 and so would have been 12 volts from the outset. I think you can still get a generator. Get back to me if you really strike out as I am pretty sure I have a spare or two in my pile of parts. May need to be rebuilt, but as I say, if you're desperate...
I have one from a Triumph car on one of my TEAs; fits not too badly and unless you're a real expert you wouldn't know it isn't original. You'll need a regulator too, and if memory serves, they aren't too cheap.
Jim
Gary Schuell
10-20-2005 11:27:59
 Re: 54 TEA alternator or generator in reply to Jim W, 10-20-2005 11:00:59
Thanks Jim. Always thought 6V was synonymous with generator and 12V with alternator. If you could forward your e-mail address, I'll file it for future reference. I will look around for a gen, and mounting brackets, and if no joy, I'll contact you. Thanks - GS
BobinKY
10-20-2005 09:44:42
I am reasonably sure that the TEA's in 54 had a generator. I say that because I have a 55 model and it has one. If your tractor has an alternator, the chances are that it was converted to 12 volt at some time. This is not a bad thing unless you are a purist and want your tractor to be completely original. There are generators available, even through this site, but you need to check and see if you have a 12 volt system first. What size battery do you have on your tractor? If you have a six volt system, you will need to go back to the generator, unless I am missing something. I am not aware of an alternator that puts out 6 volts. If it were me, I would search through used parts first for a generator, as they are expensive to buy but not too expensive to rebuild. Just my two cents worth.
Gary Schuell
10-20-2005 10:17:49
 Re: 54 TEA alternator or generator in reply to BobinKY, 10-20-2005 09:44:42
Thanks Bob - No, it's 12V - hate to 'downgrade' back to 6V, however I would like to restore it to original. I can live with 6V quirks. Haven't been able to find any www. leads on used or new generators, however.
