axle support
Jim Nye
09-16-2005 20:48:26
TO-20 front axle support needed.is this part available new ? does anyone have an extra they would like to part with? also,in the parts listing to the left there are two listings for the pivot pin,which one do I order?
thanks for the help with this and all the knowledge from so many on this site
Eric Stevens
09-25-2005 17:59:12
 Re: axle support in reply to Jim Nye, 09-16-2005 20:48:26
I just went through that with my 30. There caption says the swept axle takes the long one. Well I had to have a machine shop cut it down and then the bushing didn't fit because it was flanged so I had one made...wasted some money. So measure and call them before you order. If it is not a flanged bushing don't order on that is.
Jim Nye
09-18-2005 08:45:29
 Dave check your e-mail Thanks in reply to Jim Nye, 09-16-2005 20:48:26
Dave I sent you two e-mails Thank you.
Jim Nye
09-17-2005 20:05:27
Thanks for the info john (uk) I was hoping to have the part before tearing tractor apart.
Dave in CA
09-17-2005 19:51:01
I have a front axle support that was reportedly off of a TO30. I dont know if it the same as a 20. I bought it off Ebay for my TO35 and it is different than the one I had but I later found out that my axle support was off an industrial model as is my front loader.
If you are interested Email me and I will see if it has casting numbers on it.
john (UK)
09-17-2005 11:17:10
If you read the spec. for those two pins you will see that it is the length that varies, one is 4-1/4" long and the other is 4-3/4" long, so just measure the one that is in yours to get the correct one. make sure that you get the correct bush to go with it, the bush is listed with the pin for the longer one and separately for the shorter type,
