Basic question from newcomer
OntarioMan
09-13-2005 08:44:09
My father in law has a TO35 Deluxe which I am familiar with, I have a chance to pick up a TO20-80, which I have only seen a picture of
What are the differences between the two in terms of size, HP, parts availability, etc.
Thank-you
Jeff-oh
09-13-2005 09:13:03
 Re: Basic question from newcomer in reply to OntarioMan, 09-13-2005 08:44:09
If I had a choice of what model I would want. I definitly would look for a MF-35, or TO-35 with the two stage clutch (Live PTO) and position control. The TEA-20 would have neither.
IF the TEA is at a good price then why not, but it would not be my 1st choise. Good Price ($1000 to $1200 or less)
Jeff
Belleville Neil
09-13-2005 08:57:11
The TEA 2080 is the least powerful of the Ferguson line. The TO 35 is much more powerful. I own one of each. The 20 is slightly smaller but both tractors look very similar. There are improvements with each model. The TEA 20 will not have a two stage clutch - but depending on what you plan on doing with the tractor this may or may not be a big deal. I run a 5 foot bush hog with the 20, but I have an Over Running Clutch installed and it does a great job. Others here will give you the exact HP ratings. Goodluck, Neil.
OntarioMan
09-13-2005 08:58:36
 would just be a toy in reply to Belleville Neil, 09-13-2005 08:57:11
maybe push some snow around but not any real farm use. Thanks for info!
Belleville Neil
09-13-2005 09:07:07
 Re: would just be a toy in reply to OntarioMan, 09-13-2005 08:58:36
The TEA 2080 sounds like it would be perfect for you. The history is really cool and they are not hard to work on or restore - if you're into history. Lots of help is available here and, depending on where you are in Ontario, there are a few of us around that are willing to talk Fergie.
FYI, the difference between the 2080 and 2085 is the size of the piston. The 2085 is a little later in production and has improved HP.
