Directions For Sure Seals
Albert Betts
08-24-2005 18:33:40
UPS, delivered my Sure Seals, now all I need is the directions for instlation,,,where can I go to find them? My dealer Shop Manual nor Operation and Maintenance Manual says any thing about the Sure Seals, I've also searched the Forum with no luck..... .Thanks Albert
gerard
08-26-2005 16:27:04
 Re: Directions For Sure Seals in reply to Albert Betts, 08-24-2005 18:33:40
Leave out the middleman and throw them in the bin. I tried these on my TE20 and the brakes are just as full of oil as before.
dennis p in ohio
08-25-2005 07:51:31
Just to caution you; I tried this on my TE 20 and it failed. I later determined the seal did not have full contact with the axle shaft and the fluid literally was pouring out into the brake drum. Please inspect carefully once it is pressed into place...that you in fact have full contact between the axle and the seal.
nonac99
08-24-2005 20:37:50
Here are some nice pictures by a contributor to this discussion board.
http://www.geocities.com/wallaces_23/sureseal.html
Albert Betts
08-25-2005 08:15:01
 Re: Directions For Sure Seals in reply to nonac99, 08-24-2005 20:37:50
Thanks NONAC99,,, I printed out the instructions and Have them ready for the Instlation Process,,,Albert
