I have 2 old TE 20... the 48 TEA 20 and 49 TED 20. If I understand correctly the hydraulic pressure was changed 3 times during the TE production, 270 kg. lift capacity, 365 kg. lift capacity, and 454 kg. lift capacity. And all was done by increasing the hydraulic pressure from what I find.First question: Can I on my old TEA/D 20 tractors just replace the safety valve and get better lifting capacity, or did they do other modifications to the hydraulic system / 3 point linkage to strenghten it ? Second question:
My cousin TEF 20, has no Kigas pump, no kigas tank, and the thermostart heater plug is not working. I have not found any place they sell the TEF type thermostart heater plug, so will a MF 35 heater plug fit ? And, can he just connect a diesel pipe to such a heater plug and forget about the kigas pump ? Third question:
How can I find an original 12 volt dynamo for my TEA 20 ? I have a 12 volt battery and 6 volt batteries cost twice as much as a 12 volt battery. Fourth question:
Is it possible to find new parts for original starters on TEA 20, like the Lucas M418G #25519F ? And, is it possible to find a 12 volt starter that looks the same ? (I am running 12 volt on the 6 volt starter, no trouble with that as long as the engine starts good and it is engaged only a little while.) Fifth question:
If overhauling an 80 mm Standard engine, is it advicable to use the 85mm liners and pistons to get a little more out of the engine ? I also see here in Norway that parts for the 80 mm engine is more expensive and they also have more parts for the 85 mm engine. Bill
