stuck va,lves ,,unstuck thanks + cable going into
maplehillfrm,pat
07-03-2005 18:43:27
Thanks just wanted to let you know that I got the valves unstuck, soaked them a few times a day with PB blaster, and today went out and played with them, the #1 popped up with mimimun pressure .# 4 was a different story, had to work on it a little more, then push it ina nd pry it out again, but it is running now, except I have to redo the carb, she ran for a few seconds and died, so at least I know I have a start,,
my second question is this , there is a cable going into the right side of the transmission that is operated from a cable handle on the dassh,, any idea what this is??,, I never saw one before, I looksed at my others and they dont have it,, I can get a picture if it helps. pat
John (UK)
07-04-2005 06:07:04
 Re: stuck va,lves ,,unstuck thanks + cable going in reply to maplehillfrm,pat, 07-03-2005 18:43:27
It sounds as though you have a Sherman reduction or step up transmission fitted to your tractor in the clutch housing and that cable controls it. It's a good thing to have, can be very useful. Once you have had it running, even for a short time you will be able to get it going again now and leave it running to free everything off.
maplehillfrm,pat
07-04-2005 20:12:28
 Re: stuck va,lves ,,unstuck thanks + cable going in reply to John (UK), 07-04-2005 06:07:04
Thanks that was my first impession, but I thought maybe the transmission would be longer than others,, I will have to free it up to get her moving,, and try it out, is there any place I can get info on the sherman for rthe fergy it says nothing in my I&T small manual, thanks pat
John (UK)
07-05-2005 03:32:53
 Re: stuck va,lves ,,unstuck thanks + cable going in reply to maplehillfrm,pat, 07-04-2005 20:12:28
Only The Ferguson Epicyclic box makes the tractor longer, all the others fit within the original dimensions. For more information about the Sherman boxes, you may like to try the following site. There will be nothing in the manual because it isn't a genuine Ferguson part or option.
Link
