1986 dodge pu 360ci
tom h
05-26-2005 18:18:09
the hard way i found ballast resister to get home jumped it out truck seemed to run better. Installed new resister runs like crap, just idiling waiting for someone DIES. no sputter no noise like i cut the switch off [i can be driving mainly just strarting off but can be cold or hot no difference just kills you never know. It will do it 5 days in row then a month no problem. First question do i need resister. I would like to take it out. Is this year dodge [86] known for electrical problems? The only problems i,ve had are elec. any help or opinions i would appreciate.
cdmn
05-28-2005 21:59:11
 Re: 1986 dodge pu 360ci in reply to tom h , 05-26-2005 18:18:09
Gasahol vapor-locks a lot easier. You also might have damage in your carburetor causing it to run too lean at an idle. Do you have an electric fuel pump problem? Is there a fuel pump relay that's acting up? Is the airconditioner compressor jamming somehow?
Barry from Stirling
05-27-2005 04:44:25
I think you need a henweigh.
tractorfix
05-28-2005 05:05:29
 Re: 1986 dodge pu 360ci in reply to Barry from Stirling, 05-27-2005 04:44:25
Old Dodges are like old Fergies.Tempermental.
Jerry Cent. Mi.
06-10-2005 15:48:46
 Re: 1986 dodge pu 360ci in reply to tractorfix, 05-28-2005 05:05:29
I beleive that model has a computer in the air cleaner that adjusts the mixture and the idle vacumm advance in the distributer solinod. I had one that acted the same way and I could never fix the computer problem. I finally got a distributer from an older Chrysler V8 and installed it.
