Electronic Conversion Kit Problems
DON DOYAL
04-30-2005 07:33:55
I purchased a PerTronic electronic ignition conversion kit #1142 for my TO35. When I went to install the magnet over the distributor shaft it would not fit. Seems to be too small. Thanks in advance for any good suggestions.
Tim H.
05-02-2005 06:31:47
 Re: Electronic Conversion Kit Problems in reply to DON DOYAL, 04-30-2005 07:33:55
I just installed one on my TO-20 without any problems. Did you rotate the magnet on the shaft until the slots lined up ? Do this while pushing down, you should feel it go in. It may fit a little tight.
Bob
04-30-2005 12:45:01
Call the Pertronix factory tech support line.
They have helped me several times.
Phone: (909) 599-5955
There is also application information on their website.
Jake H
04-30-2005 07:46:27
did you get the right conversion kit for your particular distributor?...just wondering...if not it may not fit like you say
regards...Jake H
DON DOYAL
05-25-2005 23:07:17
 Re: Electronic Conversion Kit Problems in reply to Jake H, 04-30-2005 07:46:27
I sent my distributor to Pertronix and found that the distributor in my TO35 Fergerson was a Ford distributor. They were good enough to install the correct Ignitor into my distributor. They installed for (clockwise rotation) The TO35 is (counter clockwise) rotation. This may sound stupid, but do I just slide the Ignitor to the next set of holes or do I need to reverse the Ignitor. Thanks everone for all your responses.
Don Doyal
