Belly mower for a Ferguson TO 35
Oregon Will
04-29-2005 10:37:30
I saw a recent Ebay posting for a Ferguson TO20. The pictured showed a Woods 5 foot belly mower attached to the TO 20. Has anyone ever mounted and used a belly mower on a TO35. How did it work?
I have about 2 acres of mowing to do. some is in pasture that is used as play field for the kids. The remainder is in christmas trees that I keep mowed between rows.
I have considered rotary and flail mower, but have never seen a belly mower for my 35. Which mower do you folks think would be best?
Ed Hamner
04-30-2005 18:29:02
 Re: Belly mower for a Ferguson TO 35 in reply to Oregon Will, 04-29-2005 10:37:30
Will, Contential Belton out of Belton Texas makes a 72 in. cut finish BELLY mower that runs off the 3pt hitch of any kind of tractor. On and off in 10 min. I have one for my TO 35 and its a fast mower for open lawn, cut a 6ft. path at 6 mph (Thats mowing Grass). They sold out to a company called Ag-Meir,1000 E 6th ave. Belton, TX PH. 254-939-3731. A new one is about $1800.00
Dale in WV
04-30-2005 16:10:47
Are you mowing between your trees with your 35?? What's your spacing between rows?? I got a TO-30 and a 6-ft finish mower -- but my trees are 6 ft grid pattern....
Oregon Will
05-02-2005 06:58:50
 Re: Belly mower for a Ferguson TO 35 in reply to Dale in WV, 04-30-2005 16:10:47
My tress are set at 8 foot grids. How do the finish mowers work in taller grass 6-10 inches?
Zippy4554
04-30-2005 06:18:10
 I like the finish mowers in reply to Oregon Will, 04-29-2005 10:37:30
I use a finish mower. These are easily attached and removed. Since they ride on 4 wheels, you don't have any problem setting the height with the 3pt hitch.
They do a nice job, but I guess they are not as convenient for tight spaces as the belly mower would be.
mikeypa
04-30-2005 05:53:41
Don't know if this applies, but I have a friend who has a belly mower on his Ford 8N. He says if your going to put one on, plan on keeping it on, too much trouble to switch for other uses. He uses his 8N strictly for mowing. Good luck.
