Ferguson 2085 Loader
Ang
04-06-2005 20:30:04
hello all i was wondering if there was ever made a front end loader specifically for the TEA 2085 that will bolt on with no fabrication? i just purchased a loader for a massey 35 thinking i could adapt it with a little work, but its a little to big and would have taken more time and fabricating than i could have done, so i returned it luckily the gent that sold it to me took it back with no problem. any ideas appreciated
phil(va)
04-11-2005 04:31:10
 Re: Ferguson 2085 Loader in reply to Ang, 04-06-2005 20:30:04
I believe the loaders on the Ford 8N, such as the Wagner loaders, will fit it. I know they will fit the TO-30, as I put one off an 8N on a TO-30. I tried to put the same loader on a 35 and I found the 35 was about 2.5 inches longer, axle to axle, than the 30, more or less what you said. Point is, you might look for one on a 8N or 9N and it should fit.
John(UK)
04-07-2005 04:45:40
Yes there were quite a few loaders made for the TE series tractors. Ferguson made the LUO which attached to the front axle, was ok for loading a spreader but didn't lift high enough for anything else. They also made the High-Lift loader, sometimes called the "banana" loader because of its shape. But there were loaders made for it by other manufacturers.
Ang
04-07-2005 15:18:40
 Re: Ferguson 2085 Loader in reply to John(UK), 04-07-2005 04:45:40
Hi John Thanks for your reply, were can i find info and pictures of the High-Lift loader? And maybe any others that would fit.
Jim W
04-08-2005 09:59:03
 Re: Ferguson 2085 Loader in reply to Ang, 04-07-2005 15:18:40
On the home page of Holland-Brand there is a picture showing the banana loader.
Ang
04-08-2005 20:14:00
 Re: Ferguson 2085 Loader in reply to Jim W, 04-08-2005 09:59:03
Jim that banana loader looks neat.Is that a 2085 tractor? Because were the lift cylinders are mounted underneath in the picture, it looks like they are connected under the tranny and my 2085 has no mounting holes under there at all.
John(UK)
04-11-2005 14:26:38
 Re: Ferguson 2085 Loader in reply to Ang, 04-08-2005 20:14:00
That loader will fit any TE20 type tractor. It was fastened to the tractor using the studs that hold the foot rests and a bracket at the back of the seat held onto the top cover of the hydraulics
John(UK)
04-08-2005 08:44:48
If you mail me at:- fergusontractors at tiscali dot co dot uk I will send you pictures. Just tell me what you want in your email please.
Ang
04-08-2005 20:18:27
 Re: Ferguson 2085 Loader in reply to John(UK), 04-08-2005 08:44:48
Thanks John will do.
Peter UK
04-08-2005 02:54:21
You should get hold of a copy of 'Ferguson Implements and Accessories' by John Farnworth, ISBN N0 0-85236-354-0. This is available, to order, through any book shop and will tell you everything you need to know about loaders and all other Ferguson implements. This book is a 'must have' for any Ferguson owner or enthusiast.
Ang
04-08-2005 20:17:00
 Re: Ferguson 2085 Loader in reply to Peter UK, 04-08-2005 02:54:21
Thanks Peter i wrote down the ISBN no: and i will call book store tomorrow and order it.
