Ferguson 35 serial number
A. Evans
03-20-2005 11:23:17
I have a Ferguson 35 4 cylinder diesel with the serial number SDM150797. Can anyone tell me the year of manufacture and the exact model from this serial number?
Jeff-oh
03-21-2005 13:08:16
 Re: Ferguson 35 serial number in reply to A. Evans, 03-20-2005 11:23:17
I stand corrected, I did the quick SN search. A. Evans, definitly go and re-look at the SN to verify the number and model type. The model type should also be on the data plate where the SN was taken.
Jeff
John (UK)
03-21-2005 12:28:31
Its an MF35 made in UK 1959 S = Standard width..(not narrow or vineyard)
D = Diesel (23c engine)
M = Dual Clutch (live PTO)
There are similar numbers in the TO35 series but I don't think they had a diesel when that number came up in 1955 and the engine was only introduced in June 1956 so it appears to be as above.
Paul in AZ
03-21-2005 07:36:15
You may want to double check your SN. The Standard Diesel engine was not available in the TO-35 until 1958 and the first Diesel SN was 180742.
Jeff-oh
03-21-2005 05:30:49
A. Evans:
The serial number indicates you have a Standard Chasie (4-wheel normal clearance), diesel Engine, with a 2 stage clutch. The number indicates it is a TO-35 and was built in 1955.
Jeff
