Engine Swap Question, TO 30 to TO 20
Willy-N
02-21-2005 08:05:42
A freind wants to swap my complete TO 30 engine into his TO 20 Tractor. I beleive this is a direct bolt in swap out if the complete engine is used. Am I correct on this? Is there any other modification I am missing?? Thanks, Mark H.
Crem
02-21-2005 20:47:09
 Re: Engine Swap Question, TO 30 to TO 20 in reply to Willy-N, 02-21-2005 08:05:42
I have a TO-30 engine in my TO-20. I did the switch about six years ago and don't remember all of the details. I am using the TO-20 generator on mine. I bought a rebuilt engine and ordered the Z129 because of the oilfilter location. I had to change the oil pickup, oil pan, and add the external oil filter. It sure runs sweet, and lots of pep.
Jerry/MT
02-21-2005 19:46:09
I'm not sure if the Z120 bolts up to the TO-30 chasis (i.e. the bellhousing). I think the bracket for the generator is different and there is a small spacer between the right side of the engine block and where the front axle assembly bolts to the block. The rear axle is also different as I recall. Hope this helps.
Willy-N
02-21-2005 20:13:39
 Re: Engine Swap Question, TO 30 to TO 20 in reply to Jerry/MT, 02-21-2005 19:46:09
Thanks I thought maybe it would be a direct swap this helps. Mark H.
