Anti oil foulers
J Terry
09-18-2004 12:51:34
My TO 30 fouls the plugs after heavy use. I can clean them and it runs fine for awhile then fouls them again.Should I use anti oil foulers. and Its a 1952 model uses very little oil just enough to fouls plugs ,What number of plug should I use also. Thanks all.
Phil(va)
09-24-2004 08:56:46
 Re: Anti oil foulers in reply to J Terry, 09-18-2004 12:51:34
I'm with tokruys. I like the Autolite 3116 in that situation. If you haven't tried them, that might be an option. Available at most all auto stores.
tokruys
09-20-2004 03:29:24
I have better luck with Autolite 3116's.
Jerry/MT
09-19-2004 19:14:16
Are you sure it's oil fouling? If it's a black fluffy coating then it's an overly rich mixture. If it's black oily deposits then it's oil fouling. You can try hotter plugs but the root cause maybe worn rings. What's you compression look like?
mowr
09-18-2004 18:33:23
The standard Champion plug for the TO30 should be D-16. If that is fouling, your next hotter plug should be D-21. Moving to the next hotter plug is an approved, systematic way to end fouling. Anti-foulers, "will fit" plugs, etc. can cause damage.
