FERGUSON TE 20
PAT OLDS
07-29-2004 14:01:13
NEED PARTS SUPPLIER FOR TE 20-. MAINLY BRAKES AND OIL SEALS.
PAT OLDS
08-02-2004 12:58:57
 Re: FERGUSON TE 20 in reply to PAT OLDS, 07-29-2004 14:01:13
thanks for all your replies-found what i needed with your help. PAT
John (UK)
07-31-2004 07:12:36
Your MF dealer should be able to supply these parts....and Sparex can also supply these parts too and they should be available from any good Tractor Dealer.Part numbers are:- Seal and Collar kit S42078 this will repair your axle shaft, but you will need to pull off the bearing housing to replace the seal. You can also buy a kit called "Sure Seals" that will save you pulling the axle shaft apart, providing the bearing is in good condition. It fits over the axle shaft and into the end of the trumpet housing. You can get a brake lining kit S4163 and rivet new linings on to the shoes or you can get new shoes S40825 Hope that answers your question.These parts are also available on this site too (go to top of page and click on H.Ferguson)
George Holmes
08-03-2004 17:00:50
 Re: FERGUSON TE 20 in reply to John (UK), 07-31-2004 07:12:36
John is usually right about these things, but unless I'm mistaken the sure seal fits over the axle, and inside the hub, rather than the trumpet, ie, it faces outward, at least I hope so, since that's how I installed mine, lol.
George H
John (UK)
08-04-2004 10:46:19
 Re: FERGUSON TE 20 in reply to George Holmes, 08-03-2004 17:00:50
Sorry I am NOT always right, I do drop some clangers from time to time....lol
Well I have some pics of these seals fitted and that is how I interperated it. Maybe I worded it incorrectly then, usually through rushing. But I take it to fit over the axle as you say but it is part way in the open end of the trumpet housing when fitted, I don"t mean it"s fitted to the trumpet housing, just that it"s in the end of it when all bolted up. Does that make sense to you George?
