Broken TO30 starter
MG/ TX
07-04-2004 07:06:10
The "nose" (the part that holds the bearing at the drive-gear end) of the starter on my TO30 broke as in busted completely apart. I tried JB Weld and it lasted a short time. A local generator shop says the part can be brazed, but usually not successfully. I have seen the complete starters for $200 - 300, but all I need is the nose piece. I've tried the local tractor supply houses, but no luck. Is there a source for that piece by itself? Thanks.
ken/MI
07-04-2004 20:04:37
 Re: Broken TO30 starter in reply to MG/ TX, 07-04-2004 07:06:10
Any good Starter shop can get them. I have a local shop that get me mine.
Jerry/MT
07-04-2004 14:12:56
Try a tractor salvage yard. Do a web search and find one in your area.
gregg/ohio
07-04-2004 21:01:32
 Re: Re: Broken TO30 starter in reply to Jerry/MT , 07-04-2004 14:12:56
Just as a side note: On my To-35 (special) a few years ago I broke two of the starter housings before finding out that my starter pinion shaft return spring had broke,allowing gear to "slam" into housing,and breaking it in a short time. I found the items(used) from a tractor repair guy,but he did say:they were "getting hard to find" Gregg
steveormary
07-04-2004 21:22:04
 Re: Re: Re: Broken TO30 starter in reply to gregg/ohio, 07-04-2004 21:01:32
MG/TX
Had my starter nose cone welded the first time it broke. Later it broke again. This time I found a nose cone at a tractor repair shop. Then I heard that if timming is not right that will cause the nose cone to break. Called in my professional tractor friend and set timming by the book. I&T manual. Also shimmed the starter out from the flywheel housing. Had no problems after that.
steve
