Brush hog setup/ marlowe
Kevin
07-04-2004 06:31:41
Reading your response to Kent re: position control issues with t-20. I think I follow you,but I'm not sure what you are refering to when you say never use the upper support arms with the 3 pt. thanks.
Kevin
marlowe
07-04-2004 17:09:13
 Re: Brush hog setup/ marlowe in reply to Kevin , 07-04-2004 06:31:41
keven one more thing FERGUSON to do NOT have position control they have draft control that is better for plowing and hogging
marlowe
07-04-2004 16:51:49
he was useing the two arms that go from the draw bar up to the spring under the set that holds your draw bar in place for things like pulling wagons. this is a part you don't use when you are running the three point. they are called the top stave arms and has nothing to do with the set up of the bush hog
