Adjusting Valves
Todd(MI)
05-29-2004 19:05:02
I need a little help adjusting valves on a TO-30. I understand to adjust to .015 cold. I assume I adjust half at top dead center and the other half at bottom dead center but which ones at top and which ones at bottom? I have assumed before and it has gotten me in trouble so if I am off base here please let me know. any help would be greatly appreciated.
Todd(MI)
txblu
06-02-2004 09:37:20
 Re: Adjusting Valves in reply to Todd(MI), 05-29-2004 19:05:02
I once had a Z129 Continental gas and as I recall the gap was .16 and .18 hot (forget which was which but someone will correct me).I think the former is intakes and latter exhausts cause they get hotter and expand longer.
There are several methods defined in text, but I am lazy and want the easiest route. So for me that is remove the things in the way and with a cold engine, I roll the crank while watching the rocker arms. When you get to TDC (Per cylinder, not total engine timing) both rockers will be relaxed for several degrees of crank rev. back and forth. you can just rock the crank while watching the rockers and they don't move. Put the crank in the center of your rocking motion and get after it.
If you are going from any other function (inlet, exhaust), as soon as one stops moving (as you rotate the crank slowly) the other one starts. It's real easy once you turn the crank thru a full 4 cycles to see what I am talking about.
You can try to line the engine up so you only have to turn the crank twice (per the book), but I forget which one I tweaked and just do them one at the time.
Since I set them cold (easy) I add .002 to the set value to allow for valve length expansion due to heat. So my numbers are .018 and .020 not .016 and .018.
When correctly adjusted, the feeler gauge will just slide thru the gap between the head of the rocker arm and valve stem without causing the rocker arm to rise (lift up a little). If it moves while sliding the gauge the gap is too tight and if you can't feel any sliding friction it is too wide. The nut on the other end of the rocker arm sets the distance.
One final point. Most of these engines use solid lifters so they will tick a little. Hydraulic lifters were invented to take up the slack and prevent the (annoying) tick. That's what's in your car.
Point to remember. You'll never burn a valve from being too tight if you hear em ticking. So in reality the tick is music to your ears..... but you don't want them clattering at you and I have been adjusting valves on tractors for the past 25 years and never had to go back into an engine I overhauled.
Duner Wi
05-29-2004 19:12:15
I would take the spark plugs out and get # 1 cyl. to top dead center on compression stroke and adjust 2 valves. Then I would turn the fan till I got # 3 top dead cent compression stoke and adjust 2 more valves, then same thing on #4 and then #2.There is an easier way but I can't explain it so it can be understood.
Jim W
05-30-2004 06:21:41
 Re: Re: Adjusting Valves in reply to Duner Wi, 05-29-2004 19:12:15
Assuming the firing order is 1-3-4-2 (there is that assuming again), you can use the "rule of nine".
Turn the engine until valve #x is fully open, and then adjust whichever other valve # adds up to nine.
So if valve #6 is fully open, adjust #3, etc.
Jim
