Confirming my TO-35 uses a Napa 1010 oil filter...
Matt
03-11-2004 07:52:16
I have a 1955 TO-35 Deluxe with a Continental Z-134 motor. If I've done my research right, I need the NAPA 1010 or Fram C3P as the correct oil filter element. Is that right?
Planning on giving it an oil change Saturday and want to make sure I have the right parts first!
Thanks, Matt
Mike P
03-11-2004 12:59:39
 Re: Confirming my TO-35 uses a Napa 1010 oil filte in reply to Matt, 03-11-2004 07:52:16
Matt - Not sure about the NAPA #, but Fram C3P is correct. Also Carquest 85010 is the same.
Matt
03-11-2004 14:02:05
 Re: Re: Confirming my TO-35 uses a Napa 1010 oil f in reply to Mike P, 03-11-2004 12:59:39
Ok -- the C3P x-references to the 1010 so we should be golden.
I want to use the tractor this weekend, so if I drained all the oil and discovered I had the wrong filter and they ended up not having one in stock I would been up the creek with out a paddle!
Thanks!
