Dearborn Front End Loader
Don
03-03-2004 16:01:02
I need mounting Inst. to install Dearborn front end loader Model 19-23 on a TO30 Ferguson
Phil(va)
03-03-2004 16:18:03
 Re: Dearborn Front End Loader in reply to Don , 03-03-2004 16:01:02
I believe the Dearborn is very similar to the Wagner WM3 loader. I believe they both bolt to the rear axle and then attach under the front axle via a flat bracket. If so, I can tell you basically how to install, but I don't have any printed instructions. Respond to let me know if I'm correct, and maybe I can help. Does your loader have a front pump? If so, that's perhaps the trickiest part. You have to have an adapter for the tractor front pully, and you may have to shim the "stinger" on the pump. Also, it really helps to use a chain hoist. Interestingly, these loaders are interchangeable between the TO30 and 8N Ford.
z120mike
03-04-2004 08:33:11
 Re: Re: Dearborn Front End Loader in reply to Phil(va), 03-03-2004 16:18:03
Link take a look at this.mike
