Capt. Kirk
NCtim
02-16-2004 16:11:30
I emailed you and it came back undeliverable. You had some part numbers from Carquest for TEA's.
NCtim
capt kirk
02-17-2004 08:32:39
 Re: Capt. Kirk in reply to NCtim, 02-16-2004 16:11:30
nctim let me know what part you need that i was refering to and ill get the #. sorry about the email.
NCtim
02-17-2004 14:45:27
 Re: Re: Capt. Kirk in reply to capt kirk, 02-17-2004 08:32:39
Thanks Kirk. Here's a copy of the email:
Hi Kirk, you mentioned that you have carquest numbers for the input seal. Can you send those to me? Also, did you replace your crank main seal when you had it split? I'd like to replace mine as it's leaking and getting my clutch wet. Tim
BTW I have a 53 TEA-20
capt kirk
02-18-2004 07:11:12
 Re: Re: Re: Capt. Kirk in reply to NCtim, 02-17-2004 14:45:27
the seal # 472258 for input. throwout bearing #2065. pilot bearing#203ff. all carquest #s. no i didnt replace rear main i was going to wait until i rebuild engine next winter. ithink u have to drop oil pan to get seal out and every thing else i touched was a domino effect so i left well enough alone until i can afford to do entire engine.this all started with a clutch replacement and now ive redone every thing to the back next year i go from clutch foward.mr chapp or jim w can offer more insight to engine questions on tea than i can at this time.
