7 box blade on TO-35
matt jones
10-23-2003 16:29:58
Will my TO-35 with a Standard motor diesel 23C have enough power to pull around a 7" box blade. I just got a 7" blade given to me it was bent but I straighted it out and will be hooking it up shortly was wondering what to expect??
TO35
10-23-2003 17:34:49
 Re: 7 box blade on TO-35 in reply to matt jones, 10-23-2003 16:29:58
Hi Matt...I once borrowed my uncles 7ft box blade and pulled it with my TO35 with z134 cont. I had to use the draft control to raise and lower it as I pulled it along to keep it moving and from stalling.....I later purchased a 5ft and when I use it I can fill the box till it runs over with no problem.....then again it depends on what type of soil your grading so I would guess to say you could move some dirt easily but it will be a challange.....it will also help if you have water in rear tires and weights on the front...
post back and let me know how you did
best wishes
TO
