2 SPEED\HIGH LOW
JIM
09-28-2003 04:55:25
HAVE A 1954 TO-30 FERGUSON NOT SURE IF CALLED 2 SPEED OR HIGH AND LOW BUT THE PROBLEM ITS STUCK IN HIGH RANGE AND WILL NOT SHIFT INTO LOW ANY IDEA THANKS JIM
john(UK)
10-01-2003 16:23:57
 Re: 2 SPEED\HIGH LOW in reply to JIM, 09-28-2003 04:55:25
I am a little confused here you say you have a TO30 with a high and low shift. A TO30 didnt have a a high and low as standard it had just one gear lever on top of the gearbox, it could either be a TO 30 and someone has fitted a reduction gearbox to it or its a TO35 which would have a high and low lever like you say. If we assume its a TO35 if you remove the oil filler cap alongside the main gearlever and get a long strong screwdriver or something similar you can move the selector for the high and low into correct position for the lever to go back into selector. If its fitted with a reduction gearbox on a TO30 we need to know to advise you.
jeremy
10-02-2003 15:57:56
 Re: Re: 2 SPEED\HIGH LOW in reply to john(UK), 10-01-2003 16:23:57
what i was comenting on is a step up which would be on the right side as your sitting on it and down by your foot that was installed by ferguson dealerships unless he has a 35 yes it would be by the shifting lever
jeremy
09-29-2003 15:03:11
i dont have any ideas on how to fix it but may father calls that a step up he had it on his 20 he had that put in by ferguson i can ask him maybe he has some ideas and i'll get back to yo later
