Batter Cable Guage / Cable to Starter Guage?
Jeff-Oh
09-15-2003 15:21:22
I have had tenuous starts, to say the least, on my TE-20 since I got it. The motor would crank one turn a second some times two. Slow..... ...slow ..... ....slow..... ..
and the starter botton would get HOT. (My starter switch was moved to a button the dash some time in the past)
My Neg. cable conector got so I could not turn the bolt so I decided to get a new cable. I got a 1 guage cable with a heavy conector. WOW, Oh baby what a difference. The motor now turns a fast as my car starter.
As has ben sain in the past Bright ant tight makes a world of difference.
Should I'll also replace the 4 guage line from the starter to the starting motor. with a 1 or 2 guage wire?
WalJohn
09-17-2003 15:10:49
 Re: Batter Cable Guage / Cable to Starter Guage? in reply to Jeff-Oh, 09-15-2003 15:21:22
Soldered connections on 1 gauge is best for both battery cables. You can probably get them anyplace that works on large truck diesels.
Old Cane
09-16-2003 10:10:15
so where does one get 1 gauge wire? Are you then putting ends on them or are you buying them as ready-made cables?
Jeff-Oh
09-16-2003 12:44:53
 Re: Re: Batter Cable Guage / Cable to Starter Guag in reply to Old Cane, 09-16-2003 10:10:15
I got it ready made with a heavy post clamp at the local Tractor Supply Co. Store
Ray,IN
09-15-2003 19:51:35
Yes! Any system is only as good as the weakest link. Harry Ferguson 6VDC electrical systems were originally "O" gauge copper stranded wire. Most guys just run down to the auto store and buy OTC prepackaged battery cables. These are 6 gauge designed for a 12VDC system, and will NOT carry the current required of 6VDC starting motors. An often overlooked source of resistance is the bolt-together castings and other metal parts the ground cable must use to complete the circuit; unless these are clean and tight also all else is futile.
