1952 Ferguson TEA20-85
Henri
06-22-2002 15:22:48
I recently purchased this tractor. Looking for ideas regarding oil pressure. This gas engine works great although I am concerned with the oil pressure. It had an obvious oil leak at the front crank seal which I replaced. The problem is that on cold starts oil psi gets to about 55 psi which is good but when at operating temps drops to 17 psi. I will change the oil as I do not know how old it is and what it's viscosity is. But do you know of any thing else I should look for?
Thank you
