IH 345 V-8 in an M-400?
960
06-26-2007 20:25:02
We have seem GM V-8s in Farmall M's but has anyone installed a 345 International? Any special installation issues different than installing a GM small block?
r4etired
06-27-2007 17:55:12
 Re: IH 345 V-8 in an M-400? in reply to 960, 06-26-2007 20:25:02
The picture is on Tractor Photos of my V8 M It gets really full in the front with a power steering pump and a belt driven Govenor. I have it running 1850 govenored speed.It' ground speed is close to my other M,s as I run them 1800
r4etired
06-27-2007 17:23:56
[IMG]http://i127.photobucket.com/albums/p154/r4etired/Img_0169.jpg[/IMG] This is the picture if you can post it.
r4etired
06-27-2007 17:02:35
If I could post pictures I would show you mine.I put one in from an IH pickup.I put one in my neighbors 560 the winter before I did my M. When I did the 560 I made all of the cut and drill templates out of 1/8in clear plastic. I displayed the M at the 05 Farm Progress Show,Like a fool I loaned my templates to a guy in southern Missouri so he could do a 400.from there they went to Ohio.Where they are at now it's hard telling.I really want the adapter drawing to adapt the 345 crank to the M crank.IF someone knows how to get photos from photo bucket to here and can explain it to me I will try to do it,remember I know very little about computers.
CGtractor
06-27-2007 18:48:24
 Re: IH 345 V-8 in an M-400? in reply to r4etired, 06-27-2007 17:02:35
Hope this photo makes it.
Paul G. in Mn
06-27-2007 13:32:12
I seen a M at a show in Dalton, Mn almost 2 years ago that the guy had put a IH v-8 gas in. It must have came out of a conbine as it had a hydrostatic unit atached. He also had a combine rear axle used as a wide front. I had made frame rales useing retangular tubeing. It was a very neat/clean looking unit and meany hours were spent on it. I had forgot my camera that day so didnt get any pictures. Paul
markloff
06-27-2007 15:09:47
 Re: IH 345 V-8 in an M-400? in reply to Paul G. in Mn, 06-27-2007 13:32:12
I saw it too. Nice conversion, professional job.
Mark
Janicholson
06-27-2007 06:14:30
Nothing is impossible with effort, knowledge, trial and success, money time and (oh yea) effort.
The 345 is not really a small block. the success will depend on centering the crank accurately and maching the adapter plate to the torque tube. Making a clutch/FW system should not be a problem. A tractor FW should not be used due to the speed potential difference (RPM) causing potential disaster. I recommend a mechhanical governor and fail safe systems be installed to protect the safety of operator and motorists on the interstate :-) JimN
