SUPER A ENGINE CAST NUMBER
THOMASSLS
01-03-2007 18:40:22
I WAS TOLD THAT A SUPER A WITH AN ENGINE CAST NUMBER OF 354898 R1 WAS ABLE TO TAKE EITHER THE THICK 113 OR THE 123 SLEEVES BUT MY 53 345002 SA HAS THE CAST NUMBER 354898 R2 WHAT SLEEVE SET DOES TAKE?
THANKS
Stan(VA).
01-04-2007 05:57:38
 Re: SUPER A ENGINE CAST NUMBER in reply to THOMASSLS, 01-03-2007 18:40:22
You want the 3-1/4" overbore kit. If you're running without a water pump specify that for the right head gasket(large water jacket holes rather than small).
Stan(VA).
banjo
01-04-2007 00:08:50
I don't know about cast numbers but all the kits on this site go by serial numbers. From what i have seen they all sell the larger 3 1/8 piston and ring kits instead of the factory 3". Maybe IH still sells the 3". I'm no expert on the matter but i would go with serial number.
